Hi,
I‘m mostly read and try to learn, but can‘t do the same, because I‘m living in germany and a lot of modifications are not allowed - you are lucky to do all in the US
Question to ask. I will change parts of my suspension, the van has 203k mls. Want to buy Bilstein damper, mybe springs to get 2“ more high.
The threadbolt where the lower damper is connected to the radius arm has a not correct, or different - means shorter lengh! Don‘t know why, if a previous owner has cut it or for whatever reason.
before working on it, I‘ld like to ask if I have to buy a new radius arm, or is it possible to get a replacement only for the threadbolt?
Thanks for any help or tip
cheers
Gunter
