Old 06-06-2019, 11:56 PM   #1
darkstar66's Avatar
Rhino liner
I am going to have my rocker panels coated with Rhino liner and I am considering having it applied to my hood. My great white Tatanka needs a little something to break up the great white. It was suggested to me to apply 3M vinyl to the hood instead but since I am already having the rhino liner applied it seemed to make sense to do both at the same time. Is rhino a bit much for a hood application? Any opinions are welcome. Thanks so much.
darkstar66 is offline   Reply With Quote
Old 06-07-2019, 01:02 AM   #2
Have you considered running up to the line just below your badge? I think that line looks good going around the back doors it fills in around tail lights as well.That’s what I’m planning to do but I ordered darker tail lights to blend in since on was cracked from my spare tire carrier,I think if you did your hood and that little bit of white trim behind your bumper would look good! Another member did at least the sides
Zappo is offline   Reply With Quote
Old 06-07-2019, 01:15 AM   #3
These are the lights I bought,they are legal because the lights are not sprayed over but have black background
Old 06-07-2019, 01:23 AM   #4
darkstar66's Avatar
Nice and thanks. I may do just that. Probably do a computer rendition first. Do you have a link for those lights? They look great.
Old 06-07-2019, 01:32 AM   #5
Think I got them from carid,I will look for link tomorrow and post here.i do know they were about $150.00 and a compromise since I didn’t want to spend $300.00 on led and those clear/silver ones on the van pic I posted above are a bit much for me.
Old 06-07-2019, 01:37 AM   #6
I have both my bumpers already powder coated black so I’m interested to see your rendition if you don’t mind posting? My van is a 2009 so it’s a little different but I have the front grille already lineXed. No more factory chrome look
Old 06-07-2019, 01:41 AM   #7
darkstar66's Avatar
My grill is custom after market. Lol Looks OK but kind of cheaply built and I have to use a freaking screwdriver through the grill slats to disengage the hood clasp. I will post the pic for sure.
Old 06-07-2019, 01:48 AM   #8
10/4 I’ve been thinking about it for a few weeks and threw some blue tape on so when I walk by could invision.i have the same set up a lot of white
Old 06-07-2019, 10:07 AM   #9
Here you go,they have a large selection,here’s a sample of led if you got $300.00
https://www.carid.com/2009-ford-e-se...861435675.html
Old 06-07-2019, 10:27 AM   #10
I know what you mean. Looking at the original build sheet, my 2002 came from Sportsmobile with a custom grill that blocked the hood release, so the solution was to use a bent coat hanger that sticks out of the front. It's just another Sportsmobile shortcut I guess, but... really?
Coddiwomple
Rpence
Agnes
alta825
