Originally Posted by Liddy
I finally found a slider with a window, after a little bodywork and paint it's installed. Nice to be able to exit driveways turning left and be able to see without having to hit them perfectly perpendicular. The blind spot with the solid door was a real pain in the rear.
Sliding door extender, full body paint, bumpers and UJoint 4X4 conversion up next.
Liddy
Looking good! When is your UJOR 4x4 going to be installed? I just posted in the 4x4 section asking about sliding doors and wheel spacers, but I was curious what your exact plans were for the UJOR conversion. Will you be keeping the 8 on 6.5 rear bolt pattern, or using the wheel adapters to convert to 8 on 170mm?
We are about to get in line for a UJOR 6" conversion on our sliding door van, so just trying to figure out what to expect.
