I saw a homebuilt swing away tire carrier that not only used a front axle hub (like the thread on Pirate 4x4) but used the same part numbers for that rig. The idea is that if you have a front wheel bearing or locking hub failure, you cannibalize the tire carrier for parts, swap good parts for bad, and get yourself back on the trail
