Old 01-13-2017, 11:26 PM   #1
Flyview's Avatar
Lightbulb What wheels fit our E250s?
Hey guys,
I'm new to these vans and would like to upgrade from the stock steelies+hubcaps on my 1992 E250 Sportsmobile EB.
I understand our bolt pattern is 8x6.5. What is the offset? Is it safe to go lower offset (poking out more)? What, if any are some wheels from other vehicles/manufacturers that fit? What's the widest tire that will fit without a lift (at stock offset)?
Suggestions?
Thanks!
Flyview is offline   Reply With Quote
Old 01-14-2017, 06:36 AM   #2
shenrie's Avatar
There are a lot of threads here regarding wheels. You can start with this one, but a search will get you many more.
http://www.sportsmobileforum.com/for...ere-14541.html
Old 01-14-2017, 04:52 PM   #3
Flyview's Avatar
Thanks. Most of the wheels there (all so far) have been for modified, lifted vans. Although they look sweet, I'm not ready for that. Just looking for some suggestions on what alloy wheels would be a direct fit, so I can get rid of my steelies...
For example would these fit (with different tires). I contacted the seller and he says the offset is 0.
http://inlandempire.craigslist.org/wto/5931076678.html
What about these?
http://orangecounty.craigslist.org/wto/5955600514.html
How about these with tires as is (265/75/16)?
http://sandiego.craigslist.org/nsd/pts/5952624647.html
Old 01-14-2017, 05:47 PM   #4
depark's Avatar
The factory wheels are 7.0 x 16.0 with a +6mm offset.
2006 Ford E250 RB 5.4L gas
Clydesdale 4WD Conversion
VA7DTP
Old 01-15-2017, 02:14 AM   #5
Bbasso's Avatar
either of the Ford wheels looks good and fit 100%
wish I had better pictures...
http://www.sportsmobileforum.com/for...cture29048.jpg
http://www.sportsmobileforum.com/for...cture33392.jpg
Rob.
Current:
And had three other E350s...
Old 01-16-2017, 11:07 PM   #6
Flyview's Avatar
Awesome I like the first ones! If anyone is upgrading wheels and has a set please let me know!
Old 01-16-2017, 11:09 PM   #7
Bbasso's Avatar
Glad you like
I usually find them on CL for $400 or less...
Rob.
Current:
Old 01-17-2017, 11:17 PM   #8
Ive found the biggest problem with factory dodge and chev rims is the hub bore is too small for fords. Factory GM rims have a bigger hub bore believe it or not.
Here is a comparison between same years of Ford E350 , Chev Silverado 2500HD, GMC sierra 2500HD, Dodge 2500
Ford: https://www.wheel-size.com/size/ford/e-350-van/2005/
Chev https://www.wheel-size.com/size/chev...-2500-hd/2005/
GM https://www.wheel-size.com/size/gmc/sierra-2500/2005/
Dodge https://www.wheel-size.com/size/dodge/ram-2500/2005/
As you will see they are all 8x165.1 so should fit right?? Nope!
The chev and dodge factory rims have too small of center bore.
Aftermarket is a whole different thing.
KilrPilr is offline   Reply With Quote
Old 01-18-2017, 09:35 AM   #9
Lenny's Avatar
If you have a factory SMB you probably have 60/40 doors. For those who have sliding doors I would be very concerned of the offset. I have 285x75x16 with 0 offset and the sliding door barely clears. Worth it to do some research.
Lenny is offline   Reply With Quote
Old 01-18-2017, 10:34 AM   #10
Flyview's Avatar
Thanks, yes I've got the barn doors. What's the width of your rim? Offset is relative to the width.
I found a set of American Racing Outlaw II for $300 on craigslist but they don't include caps, and they can be had brand new for $450 on eBay!
