Old 03-07-2016, 08:31 PM   #1
2"Leveling/lift spacers from Maxx Lift
I have a set of 2" Maxx Lift front coil spring spacers and 2" Maxx Lift rear lift blocks,both are brand new $200 shipped.
biggordo is offline   Reply With Quote
Old 03-08-2016, 04:26 PM   #2
I could be interested in them. I have 98 SMB Extended body 2wd with the 5.4L. Are all of the blocks the same for all of the e250's? Will I need to buy new shocks? I am in Portland OR.
gbayless is offline   Reply With Quote
Old 03-12-2016, 08:13 PM   #3
Hey gbayless I was told from the guy at Maxxlift "Although the E-Kit is not certified for the earlier models, I know we have had owners of 86-98 E350s, use the 2002 version kit. The 2002 version has the longer replacement bolts and the ability to reverse them. The 2002 also has the same diameter coils as the 98. So I believe you’d be able to make the 2002 kit work." Hope this helps.
grady115 is offline   Reply With Quote
Old 09-20-2016, 08:23 AM   #4
Do you still have the Maxx Lift kits?
jkeokie is offline   Reply With Quote
Old 09-20-2016, 12:09 PM   #5
Pm Sent.
PM sent. Message length needed to be longer.
c7train is offline   Reply With Quote
