Old 07-15-2018, 06:37 PM   #11
They don’t. You have to get creative. AC ducting in the ceiling is usually terminated on the rear pillar or occasionally routed into cabinets and aftermarket registers/vents are added.
Old 07-15-2018, 09:26 PM   #12
Awesome thanks for the info...
thescottgivens is offline   Reply With Quote
Old 07-16-2018, 10:44 AM   #13
Mtsolar
I do not have dimensions because they would be incorrect. The tops flex from side to side front to back may be a little closer to a correct measurement but still not exact. Are you considering this for a NON Ford van???
thescottgivens I believe the a/c can be hidden in a cabinet and flues with registers (vents) are placed in the cabinet. I have seen the inside molds for the tops and have them molded into the shell.
You can not beat the price and they are easier than you think to mount. The most important thing is the seal, do not get cheap stuff. The flange makes a perfect seal if done right.
Old 07-16-2018, 10:46 AM   #14
Sorry scotty your post did not show up till after I answered and posted. Thanks I guess I confirmed what you said!
Old 07-25-2018, 05:47 PM   #15
Hi Vanimal- I'm looking for a poptop or hardtop for a 1986 e350.
Got anything that will work for me? Prefer a poptop, but seems hard to find.
Thanks!
petermyers is offline   Reply With Quote
Old 07-26-2018, 04:38 PM   #16
What eb tops do you have that would work for 2001 eb e350?
maxswasser is offline   Reply With Quote
Old 07-26-2018, 04:48 PM   #17
I have one 18" Extended (EB) top and 2 Regular (RB) tops left!
Old 07-26-2018, 04:54 PM   #18
Oh. How much standing room does 18" give you?
Old 07-26-2018, 05:03 PM   #19
Thanks!
Short (RB) or Long (EB) wheelbase! I have a short now that I am thinking of fitting to my 02 EB. I like it because it steps up like a cabin cruiser boat and I want to make it a clamshell type top. The problem with your year to mine is that your year is wider in the back mine is narrower. If I fit this early top I have, I will have to section it 3/4" on each side. I am contemplating whether I want to do that much work??? Let me know what yours is?
Old 07-28-2018, 11:38 AM   #20
Do not really know I am building one, I do not own a Fiberglass top van to give you specs but others here can!
Betsy
darryldickie
Priscilla
DocMP
