Old 04-17-2024, 07:19 PM   #1
nyyankees588's Avatar
H1 Scissor Jack w/ Agile Adapter, Generic Swivel Base, + more - Santa Cruz
Spring cleaning - have a handful of things available:
1. H1 Scissor Jack with Agile Offroad Adapter
2. Generic swivel base (from early 2000s GM second-row captain chair)
3. 1/2" electronically actuated ball valve (great for tank drains)
4. 1" + 2" hole saws with arbor bits
Everything is located in Santa Cruz - prefer local pickup for everything but the ball valve + hole saws (weight of the jack + swivel base will make shipping expensive). I have additional photos if people want to see more.
Hummer H1 Scissor Jack with Agile Offroad Adapter - $200
Selling my H1 scissor jack + Agile adapter combo. As many know, these are a solid jack option for lifted/heavy vans/trucks/etc (especially over the OEM bottle jack). I bought the jack off of ebay a couple of years ago and have used it off and on for rotating tires and other random maintenance on the van.
Everything functions as it should. Some scuffs throughout and the jack base has some surface rust due to sliding around on the ground. The Agile adapter works super well on pretty much all frame rails and axles. I’m only selling because I’m trying out a more compact jack setup that will live in the van (heavy duty bottle jack w/ welded-on adapter).
Seems that the H1 jacks are a bit hard to come by these days (~$130, when in stock). Agile adapter is $90. Asking $200, OBO.
ID:	50395Click image for larger version
ID:	50396Click image for larger version
Generic Passenger-Side Swivel Seat Base - $50
Selling an older swivel seat base that I pulled from the second row of a late 90s Chevy conversion van. I used it in the front passenger seat position in my van (it worked because I have a handicap conversion van with non-stock seat bases). It would likely work with a similar setup (non-stock passenger seat) or for a 2nd or 3rd row seat.
It’s fully functional - I replaced it with a swivel base from 1Der because I wanted something that would work with the stock forward/backward seat rails (which I couldn’t get to adapt to this base).
Asking $50 OBO.
ID:	50398Click image for larger version
Electronically Actuated Ball Valve - $15
New, unused (did temporarily connect to power to verify that it works). Fits 1/2" NPT thread. This uses a 3 position wiring setup: on [close valve] - off - on [open valve]. I've installed a number of these and really like them - they make it super easy to drain a gray tank without having to dodge nasty water pouring out as you open a manual valve. Retail for $36 new on Amazon, asking $15 OBO
ID:	50400Click image for larger version
1" + 2" Hole Saws - $10
Straight-forward hole saws with arbor bits. Plenty of life left, I just have duplicates that are taking up space.
2003 E250 Full Self-Build
2009 Honda Element "lil' toaster"
2013 Suzuki DR650
Santa Cruz, CA
nyyankees588 is offline   Reply With Quote
Old 04-18-2024, 12:11 PM   #2
Would you sell the Agile adaptor separately for $75 shipped? $90 shipped with the ball valve + hole saws and I'd be over the moon
bisonthecruiser is offline   Reply With Quote
Old 04-22-2024, 08:17 AM   #3
H1 Jack + Agile Adapter have SOLD locally.
2013 Suzuki DR650
Santa Cruz, CA
Old 04-26-2024, 03:38 PM   #4
Only remaining item is the swivel seat base - open to any offer on it at this point, need it gone and would prefer it be put to use vs. put in the recycling bin...
2013 Suzuki DR650
Santa Cruz, CA
My Van
bfolens
Vandemic
Charliesmom
