Old 08-10-2021, 09:15 AM   #11
wanderers's Avatar
If the truck was traveling quite a bit faster than the Sprinter it would have had a lot more kinetic energy even if it had the same mass; if I recall my high school physics correctly. I've wondered about what that would do in a collision and this seems to show the results. It's why the driver at fault often goes unscathed while killing the innocent driver and passengers.
wanderers is offline   Reply With Quote
Old 08-10-2021, 10:17 AM   #12
geoffff's Avatar
absolute speed shouldn't matter. It's only relative speed that matters, and the force is equally applied to both objects
2004 Ford, SMB 4x4, RB-50
Old 08-10-2021, 03:57 PM   #13
Just wondering.
One would wonder if an after market steel front bumper could have altered the tragic outcome.
rburklin is offline   Reply With Quote
Old 08-10-2021, 08:46 PM   #14
1der's Avatar
Very sad. The picture shows the driver door of the Sprinter removed/missing. The door frame appears to show "jaws of life" impressions.
While speed does not matter, mass would matter. A fully loaded Sprinter might be pushing 9,000 lbs. The pickup with no load would be around 6100 lbs. The front end of the Sprinter was the weakest section.
I would be interested in the actual speeds of the vehicles at impact.
Be careful.
