Old 08-12-2013, 11:09 AM   #11
E350's Avatar
Re: Metalworking
RG: You beat me to it. How about the best way to get square corners on aluminum angle? When I first started playing with steel (I designed and cut my kayak rack from a Weatherguard and added some additional square tube for up-rights, and then had a pro weld it up), I used my wood working miter saw with an abrasive blade and melted the plastic guards somewhat. Now I have a proper abrasive blade chop saw and various Makita 4" grinders (I burned out a 3.5"), but the abrasives don't cut aluminum for crap.
So Silver350, et al. what should a guy who has all the wood working tools in the world do to adapt them to cleanly cut aluminum (and also shape/grind it)?
Old 08-12-2013, 12:06 PM   #12
woodbee's Avatar
Re: Metalworking
Originally Posted by rob_gendreau
And speaking of aluminum, anyone got a good way to grind it?
You can go to a good welding supply. I use a 4" disc for my Makita grinder specially made for aluminum. It works great. It won't load up.
For cutting aluminum flats, angle. etc. I use my porta-band saw.
Woody
2009 White E-350 Modified EB-43, 4x4, 6.0 PSD
woodbee is offline   Reply With Quote
Old 08-12-2013, 12:12 PM   #13
Silver350's Avatar
Re: Metalworking
You can cut aluminum with a circular saw with a general purpose blade. Table saw, radial arm....
Jig saw also works.
Abrasive cutting disks just make a mess but you can buy aluminum specific grinding disks.
Old 08-12-2013, 12:50 PM   #14
E350's Avatar
Re: Metalworking
I like using my miter saw if all possible, but I remember using a fine toothed plywood (?) saw blade which I thought would work well on aluminum, but it just caked up. I will look for aluminum saw blades for both the chop, miter, circular and table saw as well as that aluminum grinding disk.
That Portaband saw has always scared me. FYI, one of the projects on weldingtipsandtricks.com is making a cool stand for the Portaband.
Thanks to both of you.
Old 08-12-2013, 01:21 PM   #15
Silver350's Avatar
Re: Metalworking
There's always the reciprocating saw too, but for long straight cuts nothing beats the table saw if you don't have a shear.
Old 08-12-2013, 09:40 PM   #16
Stillvanin's Avatar
Re: Metalworking
Duct tape, WD40 and a hammer... What else do you need?
2005 SMB 5.4 EB 6" UJOINT conversion
I consider myself a half-assed perfectionist
Stillvanin is offline   Reply With Quote
Old 08-12-2013, 10:44 PM   #17
Re: Metalworking
Bridgeport mill clone
1944 south bend lathe b model
ark welder
gas welder
chinese crap wire feed
3- 3 dimensional printers, Huxley,3d Touch, and a prototype machine
Love making stuff!
unimogdave is offline   Reply With Quote
Old 08-13-2013, 12:43 PM   #18
Silver350's Avatar
Re: Metalworking
Zip ties and bailing wire.
Old 08-13-2013, 04:30 PM   #19
Pntyrmvr's Avatar
Re: Metalworking
Chewin' gum.
Old 08-13-2013, 06:29 PM   #20
Tapatio's Avatar
Re: Metalworking
Callsign KK6GIY
TumbleWeed
Sarah
Vanzilla
Glenn P.
