Old 02-05-2008, 08:26 PM   #11
LoneStarJR's Avatar
They're the halogens. If we mount them upside down, Hella recommended rotating the retaining rings 180 degrees so water will properly drain from the housing.
These lights are heavy (probably 5-6 pounds each) which gave us concerns about how securely the inverted mount would be. Instead, we fabricated some brackets to mount the lights on the bumper without them interfering with access to the winch. The only negative of this solution is that the lights are not well protected, but they should be up high enough to avoid much mishap.
2008 CHEVY 6.6L DURAMAX / QUIGLEY 4X4 / RB50
LoneStarJR is offline   Reply With Quote
Old 02-05-2008, 09:03 PM   #12
Hella 4000 Mounting
Sounds like you have your Duck's in a Row .
Those are very good and durable light's and you should be pleased with them !
Greggde
Old 02-16-2008, 06:43 AM   #13
LoneStarJR's Avatar
Originally Posted by LoneStarJR
I'll ask about the BTU's when I go back in.
12,500 BTU's
Old 02-16-2008, 09:22 AM   #14
mmocken's Avatar
Send a message via AIM to mmocken
Thanks...thats a lot of amps to pull. I would assume about 1500 watts
12,500 BTU's
Thanks, Marty
Marty's 'BearsMobile'
1995 Dodge SMB EB-20 + modified for shower in back, PH Microlite Starcool. 130k miles young!
https://www.sportsmobileforum.com/alb...a37caeae3a.jpg
mmocken is offline   Reply With Quote
Old 02-17-2008, 04:59 PM   #15
LoneStarJR's Avatar
That's probably about right - I have a Honda 2000 generator to run it, but that's less than the old Starcool III which drew about 2800 watts (peak).
BTW, you asked about the overall height. From the ground to the top of my Yakima bars, it's 8 ft 2 in.
JR
