Had a chance to try the
loctite product this weekend. I had planned on using the screenmend product that this thread was created for, but I ended up having more screen than I thought I had so I ran up the street to Fred Meyer and grabbed a tube of the loctite. Ended up working really well.
Used a bunch of masking tape to hold the sagging screen where I wanted it to adhere. You’ve got to have a way to keep the screen up against what you want it to stick to which was a challenge since I had a 3’+ span I needed to repair so I grabbed a heat gun and kinda held it in place while speed drying it in between the pieces of tape. Once it was tacky, I was able to remove the tape and take care of the areas that the tape was blocking.
Overall, I’m happy with the end result as it will allow us to leave the window down a lot more often now. Only thing that would make this product better is if it was a little less runny and more of a gel.
Time will tell how well the stuff works longevity wise. Either way, it’s a temp fix but we should know how well it works once it gets warm enough to roll the windows down.
