Old 03-22-2010, 09:44 PM   #11
woodbee's Avatar
Re: Steel Pass, Dedeckera Canyon to Saline Valley
Originally Posted by saline
BTW, Inyo County always puts up the Road Closed signs during the winter on both North and South Passes due to liability. It is often not "closed" at all and worth a look see.
We had no plan to go into Saline Valley through the north pass, I had been planing to try Steel Pass before I picked up our SMB last December. Several people at the hot springs in Saline Valley also told us it was closed due to very deep snow.
On the road closed sign, the piece of paper said "big 4x4 and big snow tires, you might make it in".
Woody
2009 White E-350 Modified EB-43, 4x4, 6.0 PSD
woodbee is offline   Reply With Quote
Old 03-24-2010, 06:39 PM   #12
Christopher Thwaites's Avatar
Absolutely wonderful pics. I'm sure Phil and I both said..." yup that's where we both dinged a rim..I busted the plastic cover over the rear hub"!
Thanks for the memory. It's doable for any SMB..side ladders excluded and a spotter is a must but the worst section is only about 100yds. in length.
Not to mention the the wide flat smooth section over the pass out of Saline Valley where is broke 2 tires!
Chris/Ruth
2016 MBZ Sprinter 144" 4wd.
DIY
07 BMW 525xi wagon
Old 03-24-2010, 07:19 PM   #13
woodbee's Avatar
Thanks for all the nice responses
Woody
Old 03-24-2010, 07:27 PM   #14
Hum...I see you have no ladders. So like Bw said, I have twin ladders. Do you think it's doable with ladders on both sides Woody? We had planned that route now I'm not sure. Great writeup...thanks DaveB
Old 03-24-2010, 07:34 PM   #15
woodbee's Avatar
I don't think I would even try it with the wheel spacers some are talking about and that is only about 4" wider. Ladders I would say no way.
Woody
Old 03-24-2010, 07:41 PM   #16
Bummer. I also have a full floater. I thought maybe you could ride high on one side or something. Guess that one will have to be crossed off the list. Thanks for the heads up Woody....Dave
Old 03-24-2010, 08:30 PM   #17
My van is an RB. I don't have spacers. The narrowest spot on that section is probably 3"-4" less than the tire width. To negotiate it you have to get as close as possible to the vertical wall on the drivers side..mirrors in...because as you move through the opening the right wheels climb up the angular rock face and then drop back. For a moment you tip left to within an inch or 2 of the wall on your left. Phil's van is an EB and I think he has spacers. I broke a hub cover on the right rear and dinged the rim. He dinged his rim. Woodbee's pics show the spot exactly.
Chris/Ruth
DIY
07 BMW 525xi wagon
Old 03-24-2010, 09:15 PM   #18
wow...I just don't know. I'd like to hear from somebody that has done it with ladders on both sides but if you have to fold in the mirriors??? Is the worst spot easy to back out of if it's too tight?
Old 03-24-2010, 10:26 PM   #19
Look at the pics with woodbee standing in front. That is the spot. Yes you could back down but by now you are about 10 miles from the dunes headed north to south. Worst case, you could unscrew the ladders!!
Chris/Ruth
DIY
07 BMW 525xi wagon
Old 03-25-2010, 08:05 AM   #20
pjpvi's Avatar
The narrow width is down at tire level, not up at ladder level. I have one ladder and wasn't concerned at all about it. I do have spacers as well (I don't recall if Chris has spacers). We both dinged our wheels. I think a slightly different line would have avoided the wheel damage.
Go do it. It's a beautiful area.
Phil
Phil
- 2005 EB50 6.0PSD - SMB 4x4
