I've been developing a gas spring alternative for the helper springs to get the manual top to raise and lower easier.
There are lots of gory details but we'll start out simple. The first attempt was to just throw a 40 lb gas spring inside the helper springs to give more "assist"....
This resulted in an additional 80 lbs (extra 40 lb gas spring per side) of force when you begin lowering the top.....that was a lot.....and at the end of the travel when the roof is almost down the extra 80+ lbs of force didn't do much.
My helper springs are about 23" long and have a spring rate of 12 lbs/in which I measured with a bathroom scale and a tape measure.
...and the crossbar slides around 10" in the track from full up to full down. My actual travel is more like 9".
I don't have any pics of the first attempt; the next attempt was to use two gas springs in series..... a long 7" travel 15 lb spring and a short 3" travel 80 lb spring inside the helper springs.
Keeping the math simple this should start off around 15 lbs when the top is up and end about 80+120 lbs =200 lbs when the top is down. This worked better, but not what I was hoping for. The extra 15 lbs each side when the top is up is fine but 200 lbs or so when the top is down is still not nearly enough.
The stainless thumb nuts and the coupling nut were all purchased from McMaster-carr as well as the delrin tubing.
