Old 03-23-2011, 09:48 AM   #41
macmcintire's Avatar
Re: Jacks/Airbag, Recovery Gear and Tire kits
Jage: It won't fit behind the spare tire swing arm. I tried that. It is too thick. I also tried behind the box. If it wasn't so high it would work there, but alas, it doesn't fit there either. Now I see the value of a rack on top of the van.
Silver350: Good idea. I'll try it out today.
Mac McIntire
2003 Ford E250, 5.4L V8,
Old 03-23-2011, 10:54 AM   #42
You can't do this Mac? I'm not sure what Charlie had back here.
Old 03-23-2011, 02:11 PM   #43
He said, "It looks terrible like that!" (paraphrased slightly... )
Old 03-23-2011, 02:59 PM   #44
lactic's Avatar
From my experience, the rear spare should be covered anyway to protect from weather and UV rays. Maybe put the air jack directly on the spare and then fly the "SportsmobileForum.com" colors on a tire cover!
Hint hint Jage...
Back to a Build Sheet and a Dream...
lactic is offline   Reply With Quote
Old 03-23-2011, 03:02 PM   #45
Spare
Airbag
Held in place with Trasharoo!?
Old 03-23-2011, 03:14 PM   #46
Originally Posted by lactic
Hint hint Jage...
You'll have to buy me out of forum tees before I set up a wheelcover!
Old 03-23-2011, 08:31 PM   #47
Okay, I checked out the X-Jack today to see if it worked.
It didn't. It definitely is a two person job. The hose kept blowing off the exhaust so I had to have my wife rev the engine while I held the hose on. Then it inflated very, very slowly. Once it got blown up tight against the frame it did not go any higher.
The exhaust blowing in did not have enough force to lift the van. Tomorrow I will use my compressor and see if that makes a difference. If not, I may have to use the jack for the Toyota!
Mac McIntire
Old 03-23-2011, 10:09 PM   #48
OK, then put a hub cap on it
Old 03-23-2011, 10:19 PM   #49
Wow, I think you might have just saved a lot of us from running out and buying an X-jack. What's is rated for?
Old 03-23-2011, 10:23 PM   #50
May not be how much rather how high
