Very much so. Which engine do you have?
If you call and talk to 5 star they will, or they used to, write custom tunes if you know what you want. I think they have quit doing that mostly due to the fact that most people want mostly the same thing.
I got 3 tunes with my latest tuner on my V10 but I'll likely never change it after installing the main/first one, daily/tow. It is magic for the V10. For those unaware you have an instant changeup button with an 05 up V10/5r110 and this tune. Tow/haul off is just a great all around performance increase which minimizes the 5r110's engine brake and aggressive shifts with longer holds in each gear. The second you want that (up or down a mountain pass, for instance), just tap the tow haul button and your shifts and engine brake are strong, much stronger than driving with the tow/haul button without their tune.
If you have a 5.4l you will also love the performance tune. Back when I last had a 5.4l it was '87 performance' if I remember right. Not sure if they now call the standard 5.4 tune 'daily/tow' also.
