03-12-2009, 09:09 PM
Re: Porta-Shower Mod.
Originally Posted by MikewTV
I think this was a great idea for a modification. But, I have a question. How are you sealing this drain line when the shower is not in use?
Mike,
I insert a little plug on the end of the hose when the shower is not in use.
Originally Posted by Bronco_hauler
Ray,
Any pics of the gray water tank? I just have a gray water outlet, but no tank. I know there are plenty of options that I can use, but I'm curious as to which type you are using.
Herb,
We have a 5 Gallon Collapsible tank that SMB provided for us that works well for our use.
Here are the pics.
"I do, cellularSTEVE" :o)
03-12-2009, 10:05 PM
Wait, so Ray.. do you have a regular grey water tank too? So everything that goes down the sink will go into that bag.. and also.... when you pull the line open lets say half way through the trip to take a shower.. that 5 gallon will start filling unless you haven't used your sink at all on the trip yet.
Correct?
03-13-2009, 01:01 PM
Dave,
You are correct indeed! We don't have an actual GW tank because of our added options. So the collapsible GW is our ONLY tank. The outside spout is connected directly to the "sink drain". I added a "T" type tube and attached it to the Porta-Shower when in use. You could say that the sink and the porta shower drains to the collapsible GW tank.
03-13-2009, 04:58 PM
gotcha.. i thought you had a grey water tank.
03-13-2009, 11:09 PM
SurfG,
We also did not want to use the real estate for a GW tank inside the van, and there was no normal spot for a tank under the van. SMB TX placed a tank just about above where your photo shows the external connection that your GW hose attaches to. It is fit just forward of the rear wheek well in a spot that was empty but seemingly small. We now have a multi-gallon tank that we did not think we would have. It works great!
Greg in Austin
03-14-2009, 11:14 AM
Greg,
If you get a chance, can you post some pictures of your GW Tank so maybe I can, or SMB West, can replicate it? How many gallons is it? Thanks.
03-14-2009, 06:01 PM
I was thinking a DIY version made from PVC tube might be the ticket for GW or extra GW space. Cap both ends, add a drain and plumbing... oh and a vent.
Does anyone know if there are standards for grey water that would exceed rain or drinking water?
03-14-2009, 06:08 PM
mmmmm, great idea! Thanks Jage
03-16-2009, 08:50 PM
Herb,
Sorry it took so long for me to post a picture of the cap/handle. Been real busy at work. I also picked up a spare yellow connector to the tank from Kragen for $2 bucks today. Let me know if you can't find it there, I can pick one up and send it your way.
03-16-2009, 10:36 PM
#20
Our GW tank sits right above the drain that you have also. It's a 7 gallon.
