Originally Posted by BrianW
The front one (radiator) should run whenever you are using Starcool on 12v (i.e., driving). The one under the van is for 110v use. I can't recall if the front one also runs when 110v is on.
Did you check all fuses, etc.?
Perfect. The front fan works as you said. And a 20 amp fuse replacement got it going. I'll investigate the 110v side another day.
Thank you sir!
2016 Beta 500 RS
2014 KTM 350 EXC-F
