Old 06-06-2014, 07:39 AM   #1
danamrak's Avatar
auxillary batteries
This is probably a dumb question......We have 2 auxiliary batteries just wondering how often they should be replaced.
Dick and Anne
DABEE a 2006 Ford EB250 with penthouse top.
Life Is Good.
danamrak is offline   Reply With Quote
Old 06-06-2014, 10:01 AM   #2
Re: auxillary batteries
Depends on how well you've kept up with proper charging and discharging for the most part. Battery companies that use high quality lead have batteries that tend to last longer. A good rule of thumb is about 4-5 years on lesser grade batteries and 6 or more years on high grade batteries. I still have a Lifeline that is in great shape (not in my van) from 2006 that is used as a power supply.
Old 06-06-2014, 11:54 AM   #3
Age is certainly a factor, but I think number of cycles and how deep each discharge cycle is is even more important in determining battery life. A battery can wear out in less than a year if used often enough. Fortunately most RVers don't discharge their batteries that often or that deep.
And as Dave stated, original battery quality and care is important also. In my opinion there are too many variables to use time as a good estimate.
Old 06-06-2014, 12:38 PM   #4
geoffff's Avatar
I'm still using my house battery at 10 years old, but it has significantly less capacity. Still enough for one night's camping, though.
-- Geoff
2004 Ford, SMB 4x4, RB-50
Old 06-06-2014, 07:58 PM   #5
You need to throw in that different styles of batteries respond differently to ageing as well as cycling. Plus several short minimal cycles can do damage to some batteries as well as applying too high of a load in a short period. Applying an extra high load to too small of a battery for a short period of time can do damage even if it preforms its task. Heat is another issue. So yeah, there are several factors to consider.
For the most part we all deal with AGM batteries now days but there are some out there using wet cell types and those have different rules to follow. I suggest at least reading this site for information. It covers quite a bit:
http://www.solar-electric.com/deep-cycl ... y-faq.html
At-At
Dirk/co
Coddiwomple
Rpence
