Re: Battery Disconnect
Either the positive or negative can be switched as long as you're cutting the main cables out of the batteries and that will cut all the power to the rig. Once you've disconnected either cable, the system is not charged. But you're right on, the correct way to do it is to cut the positive cable, not the negative. On the 6.0, it's easier to disconnect the negative cable and that's why I was bringing it up to start with. Something else to keep in mind if you put in a switch that cuts all power is that you will lose any presets on your radio, and more important is that the rigs "memory" of the transmission shift points is lost and there is a proceedure you should go thru so it relearns it. The process is in the owners manual. Not a big deal, but a bit of a hassle. My whole reason here was that on the few occasions where one is doing some work and the batteries need (or should) to be disconnected, it is a serious pain in the butt on the dual battery setup on the 6.0 Especially when other equipment like a winch is directly connected to the batteries.
Scatter
2007 RB50, 6.0
K1WGB
