Originally Posted by Makalu1
Also, what is this "sail" switch and where is it located? How does it work?
Thank you!
A sail switch is placed inside either an intake or exhaust pipe or tube, they have a catch “sail” connected to a switch, triggered by airflow.
A common use is inline exhaust ventilation ducting for makeup air systems.
The sail switch is placed inside of the exhaust duct and when the exhaust is turned on, the sail catches the airflow, is pushed down and the switch is triggered which is then wired to a remotely located motorized baffle that then opens allowing fresh air in.
It is possible that the hole in your hose once held a sail switch, the wires would have powered it.
I don’t believe my Suburban heater that I removed had a sail switch, but I could be wrong.
