Old 01-21-2014, 04:03 PM   #11
depark's Avatar
Re: HAM/Cb antennae mounting
Originally Posted by BrianW
I have my CB antenna mounted on the driver's side fender channel, between the hood and the fender. (I think Jage has it there, too.) Works well, although the antenna isn't up as high as it would be on the roof (unless you get a long antenna). I have a 3'-4' Firestik (can't remember exactly the length).
There are a few places online that sell a fender mount specifically for Ford vans, with the correct hood slope angle. I got mine on Amazon last year: http://www.amazon.com/dp/B000WD3MHI/ref ... 1_ST1_dp_1.
This also appears to be the same thing: http://www.rightchannelradios.com/unive ... mount.html
Those are the type that I got my idea from.
2006 Ford E250 RB 5.4L gas
Clydesdale 4WD Conversion
VA7DTP
Old 01-28-2014, 09:14 AM   #12
Advanturetrek's Avatar
I have a similar driver's side fender channel mount for my 2m/70cm antenna. I used the "Universal NMO Ant Mt" (part UN-ANTPF) from Pro-Fit International.
The Yeti: SMB 4x4 Ford EB, super camper top, RVI interior build
https://www.advanturetrek.com
https://www.facebook.com/AdvantureTrek
Advanturetrek is offline   Reply With Quote
Old 02-12-2014, 09:45 AM   #13
ProfessorPaddle's Avatar
I'll get a photo of my setup soon.
Just remember GROUND PLANE. Our vans have an exceptional platform for radios and tearing antennas off in drive throughs.
2006 E350 6.0L (VanDelizer)
1986 Vanagon Syncro 3.3L SVX (battleCat)
1984 Vanagon GL (Chuckie)
1980 Vanagon Westy (Taylor)
ProfessorPaddle is offline   Reply With Quote
Old 02-12-2014, 11:29 AM   #14
Everyone has different mounts and setup but here is mine.
Oh year ground bolt is what is in front and don't forget to check your swr meter. The lift from ujoint on my rig had me cutting another couple of cm off to find that .8 tune.
Old 02-12-2014, 11:37 AM   #15
depark's Avatar
ProfessorPaddle, is that a Breedlove Fold Over Mount?
Darryl
VA7DTP
Old 02-12-2014, 11:45 AM   #16
Indeed it is. Only thing around that can clear a 10k predator with proper clearance and hardware.
Agnes
alta825
2006 Ford E350
Belize
