Old 08-05-2013, 01:44 PM   #1
buckkiller's Avatar
Headlight help
Just had a drivers side headlight bulb go out and have had a hell of a time trying to find a replacement. The previous owner had some aftermarket 35w Ballast Hid installed "idiot" not realizing that the new owner would actually be driving this thing all over North America and would need a more readily available bulb! I was finally able to source some locally and they were "supposed" to be a universal fitting bulb...well let's just say I have it on but it will be replaced. I am in need of some advice thanks
Buck
The Redneck Mexican
2002 E350 7.3 PSD 4x4 8inch lift pop top conversion....
"The Redneck Mexican"
2002 E350 EB 7.3 Clydesdale 4x4 w/8' lift,
Colorado Camper Van pwr top,
Van Specialties build out
buckkiller is offline   Reply With Quote
Old 08-05-2013, 04:54 PM   #2
Re: Headlight help
So you want to put it back stock?
Old 08-05-2013, 05:01 PM   #3
buckkiller's Avatar
Re: Headlight help
Well stock or if anyone knows of a great after market setup that would be easier to source bulbs for.
Buck
The Redneck Mexican
Old 08-05-2013, 07:35 PM   #4
Re: Headlight help
Just buy a full 9007 Bi-Xenon HID kit. It's hard to match up all the different ballasts. I have found the mini-ballasts to be more sensitive than the full size ballasts. Shouldn't cost much more for a full kit vs a couple new bulbs. Stick with 4500-5500 Kelvin for true white instead of ricer blue (6-8k) or purple (9k).
Should be easy to temporarily go back to stock. Just unplug the ballasts form the headlight plugs, put a bulb back in. If they are currently Bi-xenon you'll want to pull the controller fuse too.
Old 08-05-2013, 08:51 PM   #5
buckkiller's Avatar
Re: Headlight help
Carringb
Thanks will do buck
The Redneck Mexican
