Old 09-02-2014, 04:23 PM   #11
BrianW's Avatar
Re: Norcold refrige removal
I'd guess it's a blind fastener with a nut on the other side?
Old 09-02-2014, 04:29 PM   #12
Zeta's Avatar
Fridge is on the other side, and there is not a screw through the side of the fridge.
'06 RB50 SMB Diesel
https://www.tomsinclair.net
Old 09-03-2014, 11:37 AM   #13
so dirty.
The norcold has screws around the face under the trim if I recall, there shouldn't be any bolts holding the Norcold, but there are L brackets panel to wall around it. The 4 and 2.5 shouldn't be different.
viewtopic.php?f=13&t=487&hilit=removing+rebuilding
Old 09-03-2014, 01:23 PM   #14
Zeta,
Could that be a pug to fill an oops? I agree it doesn't look like any fastener I've ever seen.
Old 09-03-2014, 01:29 PM   #15
alta825's Avatar
The 4CF fridge thats in my rig (not sure the brand - didn't say anywhere) has the 4 obvious screws on the front trim panel but there were also 4 'hidden' screws that were obvious once you opened the fridge door. Those screws went directly into the side panels of the cabinet.
Those circular 'plugs' on my rig are actually the backside of flush mount bolts, the nut is on the inside of the wall and they anchor into the big L bracket that holds the cabinet assembly on the floor.
2002 EB51 7.3L w/ Stage 2- UJoint 6" 4x4 Conversion
2001 RB50 V10 Quigley- SOLD
alta825 is offline   Reply With Quote
Old 09-03-2014, 05:33 PM   #16
Zeta's Avatar
That must be it. Because I'm losing it!
Z
'06 RB50 SMB Diesel
Old 09-03-2014, 06:07 PM   #17
rallypanam's Avatar
Z
This should do it:
