Old 09-04-2022, 07:56 PM   #1
O2 7.3 diesel 2nd battery cable length
Hello Group,
Does anyone know the length of the battery cable that runs from the battery under the hood to the battery under the passenger door?
Thanks!
Johnny
2002 Ford 7.3 Diesel EB50
Mt Pleasant, Utah
dogtubs is offline   Reply With Quote
Old 09-18-2022, 03:38 PM   #2
The positive battery to battery cable should be 12 feet long.
1998 E350 7.3 Hightop
r27d is offline   Reply With Quote
Old 09-18-2022, 04:05 PM   #3
Wow! I would have guessed half that. Thanks!
Old 09-19-2022, 07:29 AM   #4
Unless I'm completely clueless about the location of the referenced battery and considering the typical E-Series is just over 19' bumper-to-bumper a 12' cable does seem a bit long.
Old 09-19-2022, 01:07 PM   #5
1der's Avatar
this listing says 85" which sounds about right. Positive terminal from battery mounted in engine compartment, down to and along the frame to the second frame mounted battery under the barn doors.
Old 09-20-2022, 12:49 PM   #6
I measured the replacement cable from a new set I’m going to install from custombatterycables.com and it’s 12’. https://www.custombatterycables.com/...troke-diesels/
Old 09-20-2022, 07:50 PM   #7
Motorwerx's Avatar
The Custom Battery cables result in a pretty significant loop on the frame. Here is the Custom Battery cables and the stock cables for comparison. Definitely not 5' worth of difference though so I'm not sure where the discrepancy is.
Motorwerx is offline   Reply With Quote
Old 09-22-2022, 05:41 AM   #8
Would the "extra" length be to accommodate lowering the battery while leaving it connected?
Dodge
lugee
Adventure Van
Neptune
