Old 05-29-2014, 05:26 PM   #1
Porch light LED upgrade
I've got the Bargman rectangular style lights which I removed from my last van since they were more or less worthless up on the side of the pop top. They were way too high and dim after you raised the top, and also they were above my awning. It was a bad idea, so I removed them and decided to mount them on my current SMB on each side. They were still too dim so I tried the 2"x1.5" (I think) LED replacements from Amazon that come with a plug and multiple bases.
http://www.amazon.com/gp/product/B00FKP ... UTF8&psc=1
Well, I didn't look closely and they don't come with the 1157 type bases, so I attempted to butcher a couple of bulbs I already had. It was pretty easy to solder on to the filament connections.
Next, I used a little dab of clear epoxy on each side to stick the LED plate to the inside of the bulb cover (diffuser).
I didn't catch a pic of the taped, sort-of waterproofed end result before I put them back together, so we'll see if condensation kills them, but they are BRIGHT!!!
Old 05-29-2014, 06:59 PM   #2
Re: Porch light LED upgrade
Looks good. Also you can install LED bulb.
Foxmaster is offline   Reply With Quote
Old 05-29-2014, 07:00 PM   #3
Nice job, Jage did similar. I wish I had done the same. That motion light has been nothing but trouble for me. I like the LED panel you used. It would be nice to have a dimmer control but better bright than dim and you can always add a dimmer version elsewhere.
Old 06-02-2014, 10:10 AM   #4
I also added two of these to our SMB standard porch light. They work great - https://www.superbrightleds.com/more...-lamp/502/787/
Old 06-02-2014, 03:58 PM   #5
Just got home from a camping trip and the lights worked awesome. I got rained on too and the lights are still alive.
