Old 12-02-2017, 01:28 PM   #1
Roof rack light bar wiring routing questions
I’m installing a new Front Runner roof rack this week along with a 55” LED light bar I bought on amazon (cheapie, $150 or so). I was wondering for those that have put any electrical on the roof how and where did you route the wiring into the cab? Hoping there’s a good clean solution someone has, preferably something that doesn’t involve putting holes in the van anywhere.
ndubes is offline   Reply With Quote
Old 12-02-2017, 02:50 PM   #2
mikracer's Avatar
Are talking about a factory roof, penthouse top, high top, etc...?
Old 12-02-2017, 02:54 PM   #3
It’s just a factory roof with an aftermarket Front Runner brand rack.
Old 12-02-2017, 07:16 PM   #4
Bbasso's Avatar
You'll need something like this
https://www.defender.com/category.js...986&id=2289996
Rob.
Current:
And had three other E350s...
Old 12-02-2017, 08:15 PM   #5
Originally Posted by Bbasso View Post
Those look slick! Looks perfect I will give that a shot thanks for the link!
Old 12-03-2017, 04:29 AM   #6
Bbasso's Avatar
Make sure you purchase the correct one.
Rob.
Current:
Old 12-03-2017, 10:02 AM   #7
rallypanam's Avatar
The only non-drilling way is to come out the rear brake light hole.. but that adds a lot of length to the wire so I'd just drill a hole!
Old 12-03-2017, 10:24 AM   #8
Not as clean, but a no holes required method is to run the wire under the rubber door seal. All my antenna wires are routed this way. You can pull the seal off the pinch weld, tuck the wires into it and then replace it. I've had no problems with closing the door on the seals with wires in them, just watch for chafe, and make sure to fuse correctly.
Tags
light bar, wiring
