Old 01-12-2011, 11:24 AM   #11
Angel's Avatar
Re: Security System and door locking
I think the alarm comes with a siren. I also got an extra siren that comes with a battery back up, in case the thieves disconnect the battery.
Angel
2000 Isuzu Rodeo V6 4WD
2006 Chalet LTW 15ft. Folding Travel Trailer 14 in. tires
Angel is offline   Reply With Quote
Old 01-12-2011, 12:19 PM   #12
Zeta's Avatar
Kinda cool: http://www.compustar.com/products/pro/RF-P1WG4-SS.html
The turbo timer is interesting for PSD's. Compatible with their Smart Phone GPS service apparently: http://www.dronemobile.com
No substitute for cubic dollars
Z
'06 RB50 SMB Diesel
https://www.tomsinclair.net
Old 01-12-2011, 12:44 PM   #13
Viejo's Avatar
Isn't the chirp gizmo also what sounds the alarm when it goes off?
You're probably right; I was thinking of the factory installed remote entry system, no alarm.
Easy to test if you can find it and it's not inside the alarm box.
2002 E350 7.3 PSD
Quigley 4x4, EB50 floorplan
Old 01-12-2011, 02:24 PM   #14
Seems like a rather obvious feature to be able to silent arm/disarm. I'm pretty sure my Jeep alarm has that feature, selectable from the remote key presses, but then again, it's been a long time since I read the manual.
Old 01-12-2011, 02:29 PM   #15
Roonie's Avatar
Mine does have a silent arm and disarm feature however you have to press both the lock and unlock buttons at the exact same time in order for it to work silently. I usually accomplish this with a 50/50 chance of it working right. Of course in the campgrounds it always falls on the failure side of the equation. Would be great to just disarm the chirp altogether.
Old 01-12-2011, 07:49 PM   #16
I wonder if you could attach a delay relay circuit to the horn. It might make your alarm sound weird, but a C1 of 50 uf (whatever that is... ) so the chirp would not overcome the delay.
These are mostly to delay radio amps when starting or shutting down, so I wonder if there is a need to discharge the capacitor. Not up on my EE...
Old 01-12-2011, 09:16 PM   #17
Probably microfarad
Old 01-13-2011, 03:02 AM   #18
Mike, I have the remote temperature on the fob. Where does it say to put the sensor, or is it just the installed alarm box that takes temperature? Mine somehow is in direct sun (don't know where) and skyrockets in temp as soon as the van is off. Makes it pretty useless.
as far as i can see the temp sensor is in the main unit. The install manual doesnt show it at all
here is the install manual to my alarm
http://www.directeddealers.com/manuals/ ... _08web.pdf
would be nice to have the sensor seperately. will see if there is something i can do about that
Michael Salzlechner
https://www.salzlechner.com
mikes is offline   Reply With Quote
