Troubleshooting a Closed Backup Camera System?
What would cause a camera to be horizontally bandy (30% rolling black bands on screen) and then go black completely? It was bandy for a long time and now it just sends black- it does send black though because if I disconnect at any point in the line the monitor changes to no signal.
I've tried other ports and double checked the power and ground. I did have voltage / power problems during the black banding time (bad batteries, low voltage, bad alternator) and it seemed to affect the camera but it didn't come back after the power problems were solved.
My next step is to swap cameras, but since that involves removing silicone and digging short wires out, I wanted to ask for advice on what it could be first. The next next step is digging all 25' of wire out and swapping the middle, and the last step is to get a totally different system which involves removing things that I'm too old to reach anymore.
Any thoughts on a camera that doesn't send image? It's a totally wired system.
