Old 01-06-2018, 10:22 AM   #1
Question Two solar controllers a problem?
Newbie SMB transit owner with prewired Zamp controller system. Just bought Nature Power solar panel and it also has a prewired controller on back of solar panel. Are two controllers a problem? Does this reduce solar energy getting to the battery? I have searched exhaustive online and no mention of this issue.
Connie is offline   Reply With Quote
Old 01-06-2018, 10:39 AM   #2
Bbasso's Avatar
I'd use the MPPT with user programmable controls (set to battery needs) and skip the other.
Rob.
Current:
And had three other E350s...
Old 01-06-2018, 10:42 AM   #3
Short Answer is yes, this would generally be a problem. The output of the "controlled" Solar Panel should not be fed into the other controller. In this case I guess your Zamp controller. You could bypass the Zamp controller and run the Nature Power and run directly to the battery system. IMO this is not the best solution. If you can return the panel and get one without the built in controller I would do so.
