Old 12-08-2016, 09:24 PM   #21
Originally Posted by daveb View Post
Here is where my smaller 20 lb tank is mounted on my EB. Sorry for the crappy picture but you can see the yellow cap that covers the fill connection. Not the best spot but has served me well. No issues with people filling it.
I will say I enjoy having a cup of espresso inside the van when the weather sucks outside. But I really don't try to cook inside the van and why the smaller tank. YMMV
Yeah that would be ideal there is a lot of space back there on each side of where the spare goes it seems like a great place for one. Did your come with it or did you install/have it installed? If so do you know the model number?
"The problem with common sense is, its not that common." Mark Twain
1999 F-250SD XCab 4x4 5.4 170k
1998 E-350 LWB (Being converted now)
www.DirkMitchell.com
Dirk Mitchell is offline   Reply With Quote
Old 12-08-2016, 09:40 PM   #22
Not off hand. SMBW did the install. I thought I'd never need propane inside but it's so nice not to have to pull out a butane (or other) stove every time I want hot water for something like tea or coffee in the early morning.
Old 12-08-2016, 09:44 PM   #23
larrie's Avatar
I had not thought of putting the propane tank behind the rear wheel. There is definitely room for one. Will have to mock something up to see if it will work with my setup.
Larrie
Old 12-08-2016, 09:59 PM   #24
Glider's Avatar
Daveb's tank looks like a Manchester. If so, it should have an ID plate on the back side, near the bottom. The plate will look similar to the one in the attached photo. The model number is circled in yellow in the pic. If you can get the model number, you can contact a Manchester dealer to price it out. If you contact Manchester directly, they can't sell you a tank, but you can sweet talk them into sending you a schematic--like the one in the second photo--that you can use to pre-test fit.
2006 SMB EB45ish.
5.4L, QuadVan 4x4
Ready to Rumble!
Old 12-09-2016, 06:54 AM   #25
Interesting Dave. I'm surprised SMB installed that. I have always assumed no one uses that spot for propane due to the chance of more rocks or whatever your wheels throw hitting it. Also, the corner seems like a more likely place to get hit in an accident than the side where most mount them. I like that little tank, though, I'd love to know more about it if you find out. Plus, with an Aluminess bumper giving more protection on the corner I wouldn't be as concerned with it being hit there.
For anyone reading that hasn't seen this thread it's definitely helpful.
http://www.sportsmobileforum.com/for...eap-18339.html
Old 12-09-2016, 08:01 AM   #26
Manchester makes RV style and van style tanks.......
The RV style has the fittings are up a bit higher than the van style.....those usually require an access door. The One in Dave B's picture appears to be the van style.
I bought the 5 gallon van style from gowesty.com They have several styles....IIRC the 5 gallon and 8 gallon are both about 8" in diameter one is about 24" long and the other about 30" long
LPG Tank | GoWesty
LPG Tank | GoWesty
They also sell a 3.3 gallon skinny one for VW vans...that should fit an SMB easily
LPG Tank with Regulator | GoWesty
Manchester also makes 10" diameter horizontal tanks, but they are a tight fit under an econoline, especially if you have rear heat/air and want to mount it on the driver's side. There are a few sites selling these online.
I used this regulator although I've had a few issues with it......had to whack it with a screwdriver handle to get it to work a couple of times.
LPG Gas Regulator (2-Stage) | GoWesty
it's been functioning properly the last couple times out; if I were to buy another (which i may) I'll probably buy this regulator from Karl at westyventures.com
about half way down this page:
Westy Ventures / Propex heaters
I use propane only for heating (with a Propex heater)....i had a couple of minor issues with my propex 2211 (one of them self-inflicted) and Karl at westyventures has been extremely helpful...if you are thinking of buying a Propex heater Karl is highly recommended.
I've probably used my heater around 15 nights so far this year, and I just refilled my tank....took 2.1 gallons so the heater uses way less propane than I expected.
Old 12-10-2016, 12:11 AM   #27
I think this is the one daveb has on his rig. They are Manchester tanks and not priced to terribly.
RV Propane Horizontal Tank on Sale - PPL Motor Homes
Old 12-10-2016, 06:36 AM   #28
Those are the ones that I mentioned above...10" and 12" in diameter. When I was entertaining using these, I took a dinner plate and used it as a diameter template under the van...things were too tight for my liking.
The images on that page show the difference between the RV style and van style for fitting location.
Old 12-14-2016, 07:05 AM   #29
Big but cheap. Maybe it could work under the rear of a van.
20 lb Horizontal propane cylinder tank RV 5 gal gauge | eBay
