Old 07-08-2017, 03:18 PM   #11
achop's Avatar
PS - On my motorcycle rack I used the brake controller circuit for the red brake lights, so they don't flash with the ambers. Works fine since it's LED. Probably works fine too with incandescent if you turn the controller up all the way.
Right ... because the vehicle sends a weaker (lower voltage?) signal down the brake controller conductor (since it's merely a semaphore, not powering a light, right?) as compared with the conductors powering lights?
I had wondered whether the brake actuator pole would work for the brake lights.
thanks!
Muy Bonita - 2000 Ford E-350 V10 Quigley with 285/75 R16s, SMB-West RB50, manual PH
achop is offline   Reply With Quote
Old 07-08-2017, 03:23 PM   #12
achop's Avatar
Originally Posted by FXRQ View Post
You could grab a running light circuit from inside the van and run up to the lic light with it's own plug - disconnect.
I really should do that ... but I guess I'm intimidated by splicing into the actual van's wiring ;-)
As for the amber/red config, sure you could do that but it might be a confusing signal for the folks behind you, don't wanna confuse the folks behind you.
Yes, and apparently lots of viewpoints on that ;-)
Old 07-08-2017, 05:22 PM   #13
thanks!
Trailer brake circuits are 12-volts, because it powers the brake actuator magnets (Or sometimes a hydraulic actuator), so most of them supply up to 30 amps. So yes, they power lights fine but with incandescent, you have to have the brake controller voltage maxed out.
One thing I've noticed is my controller doesn't say a trailer is connected which it's only the hitch rack, but it still works!
Old 07-10-2017, 10:17 AM   #14
achop's Avatar
Thanks for clarifiying carringb.
+1 for powered hitch racks! ;-)
[HOONIVAN]
Shaggy
Biggie
Berta
