Old 03-12-2010, 04:59 PM   #1
Flat Plate with GMC Diesel
I'm just 2 to 3 weeks from taking my van up to SMB Indiana for build out. I'm strongly considering the Flat Plate water heater. I understand that the engine has to be idling to circulate the hot coolant through the flat plate. I was just wondering how long it would take for the coolant to warm up enough to have hot water after cold start? Diesels run very cool when idling and I am concerned I would have to wait 30 to 45 minutes for the engine to heat up enough. I believe the Ford diesels have a high idle setting but to my knowledge my GMC van doesn't have anything like this.
Does anyone have any insight on this? Thanks.
91Tiger is offline   Reply With Quote
Old 03-14-2010, 02:31 PM   #2
fmiles's Avatar
Re: Flat Plate with GMC Diesel
I have the flat plate hot water heater in a Sprinter. I assume the GMC would work the same. I get hot water in about 5+/- minutes. I recommend that you have SMB install a hot water tempering valve at the same time with the flat plate exchanger. Without one the water can get very hot and give you a nasty scald if you are not careful.
hope that helps,
/~fred
fmiles is offline   Reply With Quote
Old 03-14-2010, 03:36 PM   #3
How quickly does your Sprinter warm up after a cold start? My Duramax can iddle for 15 minutes and the temp gauge still doesn't even register 100 degrees.
That's a good tip on the valve to keep the water from scalding. I've read that can be a serious issue with the flat plate.
