Old 12-28-2011, 05:52 PM   #21
Re: Synthetic rope winches
I have Masterpull line on my M12000 and it is super.
carl
2010 SMB
Old 12-28-2011, 08:43 PM   #22
Gnarvan's Avatar
How long of a synthetic rope can you get on a Warn M12000? I know they come with 125 feet of steel rope. The Superwinch talon 12.5 SR will take 80' of synthetic. The ability to have a longer rope on the warn might convince me to go with the Warn and just be careful with using the brake.
John
Gnarvan 1992 E350 Clubwagon
2003 BMW R1150GS-Adventure
2013 BMW R1200GS-Adventure
Old 12-28-2011, 09:56 PM   #23
Don't necessarily go for the maximum amount of rope that will fit.
From the Superwinch website:
If you still have three layers (not wraps) of rope on your winch while winching, you'll lose 19% of your winch's power. Four layers of rope and you'll lose 32% of your winch's power, and five layers costs you 42%. I attached a copy of the article from the Superwinch website.
A shorter length rope, and carrying a winchline extension for use when necessary, has a lot of advantages.
File Type: pdf WhatMostPeopleDontKnowAboutWinching.pdf (2.20 MB, 10 views)
Old 12-31-2011, 12:46 AM   #24
ANZAC's Avatar
Yes I have 100ft of synthetic line. Btw I needed the buy a 5/16" thread x 1/2" stainless button head cap screw to attach it to the drum.
The line should be tensioned in the same way you tension a steel ine, follow the Warn instructions.
There is a note about heat in Thor's install doc, about being careful if you motor the line out.
Sportsmobile-less.
Old 01-01-2012, 12:03 PM   #25
I have 100 feet of the Masterpull 3/8 superline-XD which has a breaking point of 26,500Lbs loaded on my winch. I had to do the same which was to change the bolt. I also kept the steel rope for an extension but want to replace it with synthetic... maybe one of these days. I carry 3 snatch blocks and several slings of various lengths plus some chains, shackles, rings and hooks.
