Re: Building a platform for the bed - Hexcel?
You can find honeycomb panels with aluminium, fiberglass, laminate, wood sides and the core can be aluminium, plastic honeycomb core and also foam core.
If you take the correct thickness, you will have plenty of strength to build the bed.
I have received samples, will take pictures and post them here as the weights.
Condensation will be dependent of the moisture level of the air, if you heat / cook with gas and outside temperature.
Andrew
