Old 11-21-2013, 09:27 AM   #1
Cargo/ Storage Box Inside Ford E350 EB
Does anyone know or have seen a cargo box that mounts inside the rear portion of van on the sides? Something to store tire chains, recovery straps, etc...?? I have seen where the trucks have the bedside boxes that mount around wheel well but the wheel well is too far forward in an EB Ford van.
Any suggestions?
99 E350 Extended XLT 7.3, Bilsteins, Helwig Swaybars F+R, 3.73, Eaton Truetrac, 08 Front end conversion with HID Projector Headlights, Lots of engine mods to get 425HP est...., more to come....
zmock8 is offline   Reply With Quote
Old 11-21-2013, 10:02 AM   #2
Viejo's Avatar
Re: Cargo/ Storage Box Inside Ford E350 EB
No, I've not seen such a thing. The most common tool storage solution is to cut a hole in the rear floor and hang a storage box underneath. I believe this requires moving the spare tire up to a rear bumper swing rack.
2002 E350 7.3 PSD
Quigley 4x4, EB50 floorplan
Old 11-21-2013, 10:09 AM   #3
BrianW's Avatar
If you aren't too picky, I'd assume you could use a wheelwell box designed for pickup trucks. Google "pickup truck wheelwheel box" and you'll see a ton of them.
As Viejo mentioned, the undermount boxes that SMB installs are very handy. But, you have to move the spare to the rear door and add the box, so you're looking at some work for that. (Search the forum and you'll find a forum member who sells a box kit, too.) I see the OP has an EB van, so there is plenty of room back there for the under-van box.
Old 11-21-2013, 11:21 AM   #4
http://4wheelonline.com/Tuffy_Truck_....166296.607316
Priscilla
DocMP
Clyde
ormtnbiker
