11-27-2018, 10:50 AM
Fiamma awning on a Pleasureway Traverse (or GTRV)?
Has anyone mounted a fiamma awning on a Pleasureway Traverse? What brackets did you use? Just for note the Traverse roof extends into the rain gutter so I don't think Ray's brackets will work. I think the Traverse top is similar to the GTRV from what I've read.
11-27-2018, 02:33 PM
Post up some pics of your gutter or send them to me at searay230@gmail.com
Thxs! Ray
01-31-2019, 07:53 AM
What was the outcome here ?
** No BS, No Stories, No Disappointments **
01-31-2019, 08:23 AM
If I can find the box that I have with Ray's brackets in my garage, I can give them a try on my Traverse. My guess is they will fit, because the Traverse roof still leaves the majority of the OEM raingutter clear.
It's 5 degrees out in my garage and outside right now, so it won't be today! :-)
01-31-2019, 10:11 AM
Just lookin' ahead....
HA ! Just lookin' ahead....
Fancy meetin' you here ! Thanks mahn, I appreciate the effort.
5 in the garage..... whew, that's cold !
No rush here.
01-31-2019, 10:20 AM
They’ll fit and work awesome. You’ll probably just have to drill for your awning.
02-01-2019, 09:20 PM
Thanks Mahn....
02-02-2019, 06:24 AM
Are the "Ray's brackets" the custom made for Sportsmobile poptop brackets? I think these will work for the GTRV/Traverse. I will probably have Neil at Ujoint make me something similar for mine.
Just out of curiosity, GTRV had to of made the poptop for Pleasureway in their BC location?
1999 Ford E150 GTRV Westy
2002 Dodge Ram Van 2500 CNG powered work van
2006 VW Golf TDI
2008 KTM 250XC
Santa Cruz Hightower LT
02-02-2019, 06:39 AM
Yes, but not just for SMB. They grab the rain gutter on any E-series. I've never seen a top they wouldn't work on.
There's a huge thread, or two or three, here somewhere with pics.
02-02-2019, 07:05 AM
New batch of bracket sets coming in three to four weeks. Let me know if you want a set.
Re: All Econoline vans including GTRV and Pleasureway - the main concern is the amount of filler in the gutter. If there is little to no lip (the vertical part), then the putty or filler needs to be dug out / ground down enough to allow the clamp to get a bite against the vertical lip to keep the bracket from sliding off horizontally.
