Re: Getting electric/water to "the other side"
I'm guessing that running wiring to the other side is a lot easier than running water lines.
As of right now, I'm planning all my water-related items on the SAME side of the van. So, the fresh water tank, water pump, gray water tank, hot water heater, etc will all be on the same side of the van. That way i don't have to worry about water hoses getting pinched or running uphil across the ceiling. LOL.
The electrical wiring, though, is a whole different story, because I'll be having both DC accessories (fan, pump, etc) and AC outlets on both sides of the van. So running the wiring to both sides of the van is a necessity. It's something SMB does all the time. I wonder if they keep all the wiring inside, or if they run it across the outside floor under the van?
I'm trying to keep EVERYTHING inside the van just to make life easier and not add more holes than needed.
I guess there's enough room along the ceiling and back door frame to run the wiring along that corner, right? That would probably be "safer" than trying to run wiring along the floor at the back end of the floor by the rear doors.....
Dave
Homebuilt RV Project: Design Phase is 80% Complete! (but on hold until I win the lottery)
Ford E-350 EB w/ Cruiser Top, Flip-down "Gaucho" sofa/bed, custom cabinets, AGM batteries, solar panels, water heater, fresh/gray water tanks, sink, porta-potty....
