Old 12-04-2016, 06:52 PM   #11
Here is a few pictures of my setup, the heat exchanger is surprisingly small.
The 1/2"copper passes through the floor through 3/4" water tight strain reliefs.
The water lines are plumbed with 1/2" PEX. The silver looking valve is the tempering valve to keep the hot water tame. This valve works really well, you could probably eliminate the shower mixing valve and just set this where you like it.
It was a tight fit but I managed to fit all of that in a box in the back corner behind the seat.
TeleSteve is offline   Reply With Quote
Old 12-04-2016, 07:08 PM   #12
Glider's Avatar
Great photos, TeleSteve. Do you have any pics showing how/where you tapped into the engine coolant system?
2006 SMB EB45ish.
5.4L, QuadVan 4x4
Ready to Rumble!
Old 12-04-2016, 07:13 PM   #13
That's perfect Steve! It's like you read my mind.
Old 12-04-2016, 07:25 PM   #14
I don't it was pretty tight in there. I pulled the doghouse off to get to it. I put the bypass valve on the return hose from the heater core about 10" from the firewall.
Old 12-04-2016, 07:39 PM   #15
Glider's Avatar
More questions:
1. Does the bypass valve go straight into 1/2" copper?
2. Did you insulate the run to the back of the van?
3. Does your loop come back to the heater return hose right behind the bypass valve?
Thanks!
2006 SMB EB45ish.
5.4L, QuadVan 4x4
Ready to Rumble!
Old 12-04-2016, 08:00 PM   #16
Flux's Avatar
Really nice work TeleSteve!! And many thanks for linking all your hardware too.
Old 12-04-2016, 08:14 PM   #17
More questions:
Thanks!
The bypass valve connects to heater hose. I ran silicone heater hose along the frame all the way to the back of the van where it connects to the copper before going through the floor. (similar to heater cores)
No insulation, there is plenty of heat from the engine I wasn't worried about any heat loss.
The exchanger return line connnects back to the bypass valve. The bypass has 4 ports, 2 for where you cut into the existing heater return hose, and two for the exchanger loop.
Here is the switch on the dash to activate the vacuum solenoid which controls the bypass valve.
Old 12-04-2016, 10:09 PM   #18
Glider's Avatar
Beautiful. Thank you!!!
2006 SMB EB45ish.
5.4L, QuadVan 4x4
Ready to Rumble!
Old 12-05-2016, 01:33 PM   #19
Great info here you guys are awesome!!
"The problem with common sense is, its not that common." Mark Twain
1999 F-250SD XCab 4x4 5.4 170k
1998 E-350 LWB (Being converted now)
www.DirkMitchell.com
Dirk Mitchell is offline   Reply With Quote
Old 12-05-2016, 10:25 PM   #20
Glider's Avatar
With apologies for my lack of knowledge on this point: is coolant always flowing through the heater core, regardless of cab heat being on or not?
2006 SMB EB45ish.
5.4L, QuadVan 4x4
Ready to Rumble!
