Old 12-30-2018, 06:52 PM   #11
Marcel Huijser's Avatar
Originally Posted by WanderingBob View Post
I saw a vid on YouTube a while back where someone removed right front fender and installed on an internal structure (firewall?). Can't find it now, but may be worth a search
Not sure if that helps.
Thank you! Yes, I think I saw the same video. They installed the coolant heater in a Ford F550 truck under the right fender
Marcel Huijser is offline   Reply With Quote
Old 12-30-2018, 06:54 PM   #12
Originally Posted by boswellbear View Post
You can just see the exhaust side of the heater in this image. It's on the driver's side, just aft of the front wheel. I've had it there for about 15 years. No problems, works perfectly - even in the mountains of Colorado, as well as the upper Midwest winters.
Attachment 24739
Thank you! I see the exhaust and muffler in the image, but where did you install the actual coolant heater unit?
Old 01-19-2019, 03:54 PM   #13
The Hydronic coolant heater is now installed.
The unit is mounted under the van, near driver door.
It is connected to the coolant lines that run near there from the factory (in case you want to heat to the rear of the van with the coolant).
More info later after testing.
Sportsmobile Forum - Marcel Huijser's Album: Installation Espar S3 coolant heater - Picture
Vandit
aarcaris
Rufus
LARufus
