Old 02-12-2014, 09:49 AM   #1
MrHenrietta's Avatar
95 7.3 E350 high top passenger
http://www.ebay.com/itm/Ford-E-Series-V ... ars_Trucks
2003 7.3 UJOINT 4x4 SMB
MrHenrietta is offline   Reply With Quote
Old 02-12-2014, 10:55 AM   #2
Re: 95 7.3 E350 high top passenger
Couple quick observations:
1) Some of the "updated" body bits and pieces up front indicate a probable collision repair (and he does say a "minor fender bender" in the Q&A section when questioned about the repair history).
2) The rear seats were modified to fit the old quick release brackets. Those brackets do not have enough strength for integrated seat-belts.
The good however: 1) Powerstroke 2) Reman transmission which should mean it has the 4R100 mechanical updates 3) Mobility-van high-roofs are required to have integrated rollover protection.
Old 02-12-2014, 05:10 PM   #3
I believe 95 is E4OD?
At least that's what I believe mine has...
And it's in Chula Vista. My guess is one of Javier's conversions...
1995 SMB Quigley 7.3 EB
"a quality, stock 460 is a real pleasure" - twogone
blupaddler is offline   Reply With Quote
Old 02-12-2014, 05:50 PM   #4
That is correct. It will have an E4OD, however all Ford remans and any reputable rebuild will have the updated internals that the 4R100 has.
Old 02-12-2014, 09:19 PM   #5
Interesting front suspension components. Anyone know what they're from?
Old 02-12-2014, 11:13 PM   #6
2005+ F250/350 with some fabricated frame-brackets. It looks like instead of building inset brackets to fit the radius arms to the wider E-series frame (ala QuadVan) they simply pried the radius arms apart forming a trapezoid instead of keeping them parallel. I imagine this would probably cause some suspension binding and extra stiction.
