Old 05-30-2013, 10:10 PM   #11
Re: 6.0 fuel filter replacement
Originally Posted by sdwindansea
Originally Posted by JoeH
Originally Posted by ecmccarthy
Consider picking up a Fumoto drain valve for oil changes. Makes it real simple and less mess when dealing with 15 qts of oil. http://www.qwikvalve.com/fumoto-f111s-valve.html
I've never found removing the drain bolt to be much of a hassle or messy, especially when compared to draining/removing the two Amsoil filters. Is there any danger with the Fumoto drain valve in relation to driving off-road and something hitting it?
Good question. My 2cents is there's plenty of other things that will rub/hit before your oil pan and the drain valve which hangs down another inch.
2011 VW TDI Golf for hwy fun
Old 04-12-2016, 06:04 AM   #12
Wannabee Explorer's Avatar
Originally Posted by ridintall View Post
Here's a good article on how to go about it:
http://www.forddoctorsdts.com/articles/ ... -06-06.php
I changed mine every 10K miles. The diesels like clean fuel, don't skimp on intervals or filters...OEM only!!!!
Also, take a good look at the filter along the frame rail. If you still have the OEM fuel tank and it's starting or has been delaminating, you'll see grey flakes in the filter. This can cause low fuel pressure or over time the pieces can get small enough and make it past both filters...both conditions will kill the injectors. If you're seeing signs of tank delamination get it fixed ASAP. You can get the tank reconditioned where they'll boil/blast out the interior and then recoat it.
Good Luck!!!
I really need this and the link no longer works, any ideas? Thanks!
2004 EB E350 4x4 Diesel
Wannabee Explorer is offline   Reply With Quote
Old 04-12-2016, 09:20 AM   #13
Try this one: 6.0L E-Series Fuel Filter Removal - DTS Articles - Articles - Articles - DTS
Old 04-12-2016, 05:26 PM   #14
It worked, thanks!
Serenity
Makalu1
MSH MBL
Skivvie
