Old 07-24-2018, 12:44 PM   #71
Wouldn't this be a perfect for those with 5r110 (1/2" hose) its 3/8" with a 1/2" barb
https://www.zoro.com/zoro-select-hos...h2/i/G3454114/
jjuan is offline   Reply With Quote
Old 07-24-2018, 02:18 PM   #72
Unfortunately not. I bought one and tried. The threads on the TruMax are not NPT. I don't know what they are called, it's a type commonly used in hydraulics I believe.
crawpappy is offline   Reply With Quote
Old 07-24-2018, 02:41 PM   #73
ShuttlePilot's Avatar
On my Trucool Max I installed in 2011, just for date reference in case there has been a change, the cooler is 3/8 inverted flair. I went to a well stocked hydraulic shop that catered to race cars and the guy was able to accomplish what I needed in two fittings. 3/8 Inverted flair to AN adapter and AN to 1/2" barbed hose. A few more convenience fittings of a 90 in AN and a taped coupling to insert my thermostat that turns on the Trans cooler fan. I was concerned about the restriction of the stacked fittings since I was getting a new transmission installed at the same time by John Wood. John said 3/8 fittings would be fine but to maintain the 1/2" hoses. So that's what it's been for the last 7 years.
- Eric
2005 SMB RB 4x4 6.0 PSD
A rocket on the pad is safe,
Old 04-07-2021, 07:33 PM   #74
vandiesel's Avatar
This is the correct adapter that doesn’t exist. I used JB weld and glued the cutoff 1/2 Barb off another fitting over the 3/8 Barb included in the trucool box. Hopefully it won’t leak.
Old 04-07-2021, 07:51 PM   #75
My solution was similar except brazed instead of JB weld. One failed so batting 2 for 3.
2011 VW TDI Golf for hwy fun
Old 04-08-2021, 07:08 AM   #76
vandiesel's Avatar
I was thinking of soldering one this morning and compare. I let the JB cure overnight so maybe I'll keep a spare. Surprised yours failed. Leak or total failure of braze?
Old 04-08-2021, 08:30 AM   #77
It was a less than perfect braze. The filler didn't completely fill all the gaps. Just enough to work for a while. And of course I had a tru-cool fail as well at the support so there's that. Could just be me.
Old 04-08-2021, 07:33 PM   #78
vandiesel's Avatar
All done! 164 degrees on my test drive with hills. No leaks on JB welded fitting.
