Old 04-23-2013, 01:44 PM   #1
84 Chevy 1 ton Engine swap or rebuild?
Hi Guys,
I just picked up an 84 Chevy g30 van with a 4x4 conversion done out of Salt Lake City UT.
The engine is in need of an overhaul as there is a significant knock in the lower end. My question is would I be better off overhauling the current motor with a rebuild kit or swapping out the current 350? How difficult would it be to install a new Chevy EFI? Any experience and or suggestion/ advice would be most appreciated.
HVYCHVY is offline   Reply With Quote
Old 04-23-2013, 08:04 PM   #2
buckkiller's Avatar
Re: 84 Chevy 1 ton Engine swap or rebuild?
Ohhhh 12V Cummings!! Ohhhh yaaa
Sent from my DROID RAZR using Tapatalk 2
"The Redneck Mexican"
2002 E350 EB 7.3 Clydesdale 4x4 w/8' lift,
Colorado Camper Van pwr top,
Van Specialties build out
buckkiller is offline   Reply With Quote
Old 04-23-2013, 08:16 PM   #3
I think only the 4BT fits in the old chevy vans (probably the new ones too, since GM couldn't even fit the big block in after the '03 update). Plus that's a lot of torque for a unibody
That said.... there's lots of good options for high-performance GM crate motors, EFI optional. Just take quick browse through a Summit catalog, and you shouldn't have trouble finding something powerful that will mostly drop-in. Any chevy small block should bolt in, and crate motors can be ordered with their own wire harnesses and fuel delivery systems.
Old 04-23-2013, 08:21 PM   #4
I give a big second to the cummins swap.
Chris at Ujoint is doing the Cummins Swap on my Van now. If you call him to discuss
I am sure he will let you know what it entails and if possible.
There is some work involved and requires knowing quite a bit.
My van is the CopesCobra just in case you wish to call him and mention
I suggested it may doable. He can share with you the things that require
extra care when doing the cummins swap.
Good luck in whatever you do...Sounds like it will be a great end result--new engine
new experiences.....
1994 SMB 7.3 with Quigley and Agile offroad goodies
1982 Wanderlodge Blue Bird FC33
copescobra is offline   Reply With Quote
Old 04-24-2013, 10:29 AM   #5
Awesome! Thanks guys! I will keep ya''l posted on the progress. Cumming swap is tempting but probably out of my price range. Leaning towards a 6.0 FE, just have to find one with the wiring harness, ECU, etc...
Old 04-26-2013, 03:17 PM   #6
I have a chance to buy a low mileage LT1 from a 96 Caprice Police car. Includes wiring Harness, ECU and is already re-programmed to delete emission, security etc. Aside from trans adapter, motor mount adapter etc. What else should I expect while making the swap/ install? Aside from the severe knock in the lower end of the current 350 there are quite a few components that are still in great shape such as the alternator, dist, etc. Advice, suggestions, experiences?
Old 04-26-2013, 05:43 PM   #7
The alternator on the LT1 is clocked different from yours. If you don't mind pulling the case apart, you can simply re-clock it to fit the LT1.
I strongly recommend re-sealing the LT1 intake manifold prior to installation. The ends are sealed only with RTV, and it dries out after a while and makes some good oil leaks. GM has very specific instructions on re-sealing it, down to the bead-size on the new RTV.
Also I recommend replacing both the oil-level sensor, and the knock sensors, because both have a tendency to rupture internally causing oil leaks. Another problem area is the distributor. It's behind the crank pulley and water pump housing so its a PITA to replace it in the car (don't lose the intermediate shaft when you pull the water pump!). MSD makes a nice upgrade, but its $$.
Here's one I did a mild build on for a Qatari customer.
Old 04-27-2013, 11:27 PM   #8
I bought a low mileage 5.7 Chevy EFI out of a wrecked 93 Police Blazer. Engine is complete minus the wiring harness. I know there will be some obvious changes to make the swap. Can anybody give a bullet point style breakdown that includes what additional components and modifications I will need to complete the job? I am trying to stay low budget. I have about 2k at the moment for parts and labor. I will post pics shortly to document the project.
Old 04-28-2013, 02:41 PM   #9
The Blazer motor should be almost a direct swap. The front-ed accessory brackets will be different, but you can swap that over from your old motor. Ditto the mounts.
For wiring, I recommend these guys:
http://www.painlesswiring.com/
Note they don't sell direct. I buy their stuff through NAPA. (I'm not sure all NAPA stores are Painless dealers).
The Hulk
Hulk
Vanna
gahamby
