Old 12-10-2017, 12:40 PM   #1
Axle and ratio chart
I have been trying to decode the ratio and axle. Some charts say different thing. What do i have? Thanks
Langan is offline   Reply With Quote
Old 12-10-2017, 02:23 PM   #2
From what I can find, the top one (C4) should be a Dana 60 with 3.73 with a limited slip. The bottom one (C2) should be a Dana 60 with 3.00 (never new that was available?) with limited slip. Are you junk yard searching, or do you have 2 vans?
Old 12-10-2017, 03:25 PM   #3
mikracer's Avatar
Whenever you see a letter in the axle code, it designates it as a limited slip. When the code is 2 numbers, it is an open diff.
Old 12-10-2017, 03:34 PM   #4
The C4 is one i think i am buying the C2 is back up plan. Thanks fo ansewer. My current van has 7 and axle 34 i am hoping the 3.73 are same as current van. Thanks
Old 12-10-2017, 03:54 PM   #5
Great info . Do you know what the 34 is?
Old 12-10-2017, 04:00 PM   #6
I got my info from here: https://www.ford-trucks.com/forums/2...tio-codes.html
Old 12-11-2017, 04:06 AM   #7
Slightly off topic but since we're already talkin' 'bout rear axles.....
Are the threaded axle vent tube fittings generic to Dana's (mine = 34) or super specific to the exact axle assembly?
I need to raise my left side brake lines slightly to clear a new U-bolt installed for a Hellwig rear sway bar.
Old 12-02-2023, 02:34 PM   #8
ADDED NOTE: The 2011 E-Series FSM specifies C4 - 3.73 ratio. limited slip, single rear wheels
Just an FYI (and I know it is old but just adding to the knowledge base)
I just bought a mildly abused 2011 E-350 5.4L 4R75E (Trans code Q but the cross brace is marked 4R70W) Super Duty with the C4 axle designation.
The build code is:
3.73 2014981-3 L-S
The -3 does not show up here:
https://www.crawlpedia.com/dana_60_bom.htm
2014981-1 Dana 60HD '11 (Ford) Rear 3.73 4.10- 35 Sp. C-Clip More..
2014981-2 Dana 60HD '11 (Ford) Rear 4.10 4.10- 35 Sp. C-Clip More..
I'm assuming the -3 or the L-S stands for limited slip as implied by the C4 axle.
posplayr is online now   Reply With Quote
