Ye haw!! Got it all back together and driving well again!
It turns out that the rear drive shaft did have grease jerks, it also appears that the PO did not have a clue they were there
. When I pulled everything apart the rear U-joint came out as dust. The fronts were also bad and is what caught my attention when this all started. The front drive shaft are indeed sealed units so I hope all is well with those.
Question about the front drive shaft, When the Atlas T-case is shifted in 2 wd high and the front hubs are unlocked does the front drive shaft still rotate? Or does it just go along for the ride intill you shift into 4 wd and lock the hubs? Some past trucks Ive owned do and some don't depending on what sort of 4wd system is in them.
A big thanks to "BIGVANS" for the video info and a big thanks to "BajaSportsmobile" for the recommedation of doing both front and rear.
4X4Kayaker Im glad your repair was as easy as mine, got to love and appreciate the cheap ones.
TraceyAZ
