hi im buying a 2003 ford 350 quigley 4x4 van ,im looking for some cool new sneakers for it, but most after market rim companys dont list a 03 e350 van, are the f 350 trucks the same as my van? thanks mike.
No- the F350 are "Superduty" which is a metric pattern (170mm) and doesn't match the 8 on 6.5" that you probably have. (Someone with a quigley back me up).
Fords that predate the Superduty, Dodge and Chevy trucks all have (I think) the 8 on 6.5"
Actually the 2008 Quigley's have 8x170 just like the F350. My tire guy didn't believe it either, but it's true. They also require 17" rims minimum to clear the larger brake rotors.
