Old 04-23-2019, 01:34 AM   #11
I guess this axle won't work for my application then, do you think I'd have better luck finding a FF dana 60 out of a van with ABS? What years would be best?
gwbuild is offline   Reply With Quote
Old 04-23-2019, 06:22 AM   #12
Negatory. Stick with a 2009+ cutaway axle.
There's only one year (2008) van axle which will be fully compatible and be full float and have the big brakes. And even then there's a chance you get the "wrong" tooth count on that year, which would require swapping tone rings.
What was the axle in your pics out of?
Old 04-23-2019, 04:03 PM   #13
2009 cutaway, 27,000 mi. plumber was using it until wrecked.
Old 04-23-2019, 04:55 PM   #14
That should be the one you need. Just need to figure out when they did with the outboard wheel speed sensors.
Old 04-23-2019, 05:30 PM   #15
Would I be able to retrofit this rear end with speed sensor axles?
If I understand correctly, the outboard sensors are mounted to the axle shafts? I would imagine they are different than axles with no sensors.
I feel bad about all these questions, but haven't been able to find answers to my questions elsewhere.
Old 04-23-2019, 07:42 PM   #16
No retrofit is needed. Either the sensors are there and you just need to plug into them, or somebody removed the sensors and you'll need to replace them.
