09-18-2007, 02:46 PM
Front end alignment
Looks like I may have to have my van's front end aligned. It looks like both my front tires are wearing on the inboard side of the tread. I think this is a toe-in problem if I understand my alignment issue correctly (I doubt that I do). Has anyone had their front end aligned, and if so, any advice? Does SMB have the specs available so someone else can set it up properly?
thanks,
09-18-2007, 07:37 PM
Herb - I got a set of specs in my binder from SMB. Mine is an '07, but if you want what I have, let me know and I'll look 'em up and send them to you.
Scatter
2007 RB50, 6.0
K1WGB
09-18-2007, 08:08 PM
Ditto with mine (05)...
Anyone want to volunteer to contact SMB and see if you can get parts lists and alignment charts for ALL years of SMB 4x electronically (like the original Word file or whatever), then I can post them here...?
Ditto with Quigley and any other specifications we can get electronically.
09-19-2007, 05:57 AM
Peter, one of the service managers at SMB West, got back to me and gave me specs for my conversion. I don't know nearly enough about alignments to know if these numbers are for all similar builds (my van is an '06 model year), or does it depend more on the DynaTrac front end? I'm curious as to what specs other people have for their vans.
Camber
LF .15
RF .8
Caster
LF 4.05
RF 4.75
Toe
1/16â€Â
09-19-2007, 07:10 AM
My '07 specs are:
Camber
Left: -1.9
Right: -1.7
Caster
Left: 5.9
Right: 6.2
Toe = 1/16 inch
Scatter
2007 RB50, 6.0
K1WGB
09-19-2007, 03:21 PM
OK guess mine is an 05... duh!
Caster Right 4-8p (actual 5.1)
Caster Left 4-8p (actual 4.5)
Camber Right 1/8n (actual 0.05)
Camber Left 1/8n (actual 0.05)
KPI (blank)
Toe 1/16 inch
12-19-2008, 08:58 PM
Scatter and Jage,
Where did you acquire your alignment specs?
Is it somewhere in the mound of paperwork I got from SMB? or is it through a call?
Thanks,
Greg in Austin
oh yeah....
Greg in Austin
12-19-2008, 09:29 PM
Mine was on a sheet the PO handed me with my paperwork, but when I pulled it up for the above post it looked more like a report from an alignment shop than SMB specifications.
12-19-2008, 09:35 PM
Parts list but no specs info.
Here is some info on the 2006 Pro Rock 60
Tie Rod Ends:
Moog # ES2082R Dynatrac # DA60-3304-T
Moog # ES2083L Dynatrac # DA60-3304-U
Ball Joints: Old Spicer # 707238X Now 700238-2X
(My parts man had to order from Dynatrac and could not cross reference)
Brake Caliper/Pads: E-350
Brake Line: Stock Ford E350
Brake Rotor: 1995-98 Ford F350/Auto Specialty AR8553/ Dynatrac # DA601125-D
Wheel Studs: Dynatrac DA60-1107-AL / Dorman # 610-283
Timken Wheel Bearings:
Inner: 387A------------------Dynatrac # DA60-1244-A
Inner Race: 382A Dynatrac # DA60-4222-B
Outer: LM104949------------Dynatrac # DA60-1244-B
Outer Race: LM104911 Dynatrac # DA602-4222-C
Grease Seal: 48816------------------Dynatrac # DA60-1175-D
Spindle Spanner nut: Spicer # 33732-----Dynatrac # DA60-1195-A
Lock Washer: Spicer #33733 Dynatrac # DA60-1198-A
Axle Shaft U-Joint: Spicer # 5-332X---Dynatrac # DA69-3249-A
Inner Axle Seal: 36487-------------------------Dynatrac # DA60-3254-A
Warn Premium Manual Hubs: Warn # 38826
Yoke: 1350 Series Spicer # 3-4-5731X
ABS Sensor Driver Side:------GM 15990503
ABS Sensor Passenger Side GM 15990504
This is for a 2006 Pro Rock 5500lb rated front axle and may vary from year to year.
For more info contact Ebber @ SMB West or
Dan @ Dynatrac (714) 596-4461 ext 216
