Originally Posted by vlamgat
Originally Posted by rob_gendreau
I would hope you mean you'd accelerate to compensate for the loss of speed AFTER the blowout...not when it is imminent
Rob
Michelin has a video on Youtube that is quite specific in advising that upon the blow out, you floor the gas and then slowly lift off. You do not take your foot off the gas and absolutely do not hit the brakes.
I don't want to nick pick, but it is sorta important. What they recommend is that you stay on the gas; "flooring it" is not what they say, for good reason. I realize that flooring our vans doesn't exactly pin you to the seat, but that BMW in the video would probably react unpleasantly to that input. The idea is to not to do anything to unsettle the vehicle. It's very much like dropping two off on the track.
And speaking of the track, that IS one place where you do work with hot tire pressures, not cold (at least once you start lapping). The rule of thumb we used is about 1 psi increase for every 10 deg F the ambient temperature rises (have never seen the 2 degree figure). But even within the relatively controlled environment of a track there are things like track temp, and whether you parked with one side in the sun, etc. You DO notice a difference, especially at a place like Thunderhill in August. Gets REALLY greasy in the PM. And sun in Tucson on your tires can make a big difference from say a 68 degree AM to a 108 degree PM, but generally it's taken into account by the manufacturer and unless you're seeking the ultimate in performance you default back to a recommended cold temp to start.
And for max perfomance you have to look at the temp of the tire itself, not just the air within. It's like a more specific version of the chalk test. You'll see dudes with their pyrometers sticking tires like crazed accupuncturists.
And if you want to see what truckers do, there are calculators online. Here's one example:
http://www.yokohamatire.com/air_pressure_calculator
